Front near side hub
Hi
Apparently the front near side hub needs replacing on my Clio.
Car is a 58 plate with 38k on the clock. Anyone know where I can get this part from fairly cheaply and what is the cost difference between getting it done at a dealers?
Also at around 30 mph the rear left makes a squeaking noise but applying brakes or accelerating a bit stops it...any ideas?
Thanks in advance
Aran
When you say hub, do you mean the bottom swivel has play and needs replacing (it's part of a hub).
If so, search some threads on here, the hub is approx £200 plus fitting. You can get the swivel pressed out/swapped for about £40, but need to remove the hub first and possibly send it away.
I've swapped both hubs on the drive at home, it's not too difficult but took me a few hours the first time I did it!
Ian.
