First lambda sensor
Legend@wheels
Gold Member
Hi folks
For who changed their first sensor-did you do it underneath or did you have a good access from the engine bay up?
And the tools that were needed :spanner only right?(remember which?)
You need a 22mm spanner most lambdas are that size and from underneath it's hard to see and disconnect the Lambda at the same time you might end up lying over the top of the engine to reach down and disconnect the lambda its got anchor plug on a bracket right of the flexis.
Reactions: Legend@wheels
hi
I see the connector (like in the pic) from
above but i cant see the sensor itself.
The sensor only from underneath?
