Final Drive Ratios 5:0:1 needed for Clio 3 RS
Hi!
I've recently bought a final drive gripper for my Clio 3 RS with an ratio of 5:0:1. I've installed the final drive and now have issues with the shift lights in my dash2pro. They do not come up at all currently. I assume i have to edit the gear ratio in my dash2pro.
Does anyone maybe the ratios for a 5:0:1 gripper? I need the following:
Gearing information (kph per 1000rpm):
1st gear:
2nd gear:
3rd gear:
4th gear:
5th gear:
6th gear:
Gear ratios
1st gear ratio
2nd gear ratio
3rd gear ratio
4th gear ratio
5th gear ratio
6th gear ratio
See attached files from my Dash2Pro, maybe this helps.
Car details:
Renault Clio 3 RS Phase 1 (197)
Gearbox TL4
Thanks a lot!!
Clio Gearbox Compare
here the complete gear and graphic of 197 (tl4 003, tl4 024) and 200 (tl4 031)
TL4 003
1 3.181
2 1.947
3 1.482
4 1.205
5 1.026
6 0.872
1st 11/35
2nd 19/37
3rd 29/43
4th 34/41
5th 38/39
6th 39/34
TL4 024
1 3,18
2 1,95
3 1,48
4 1,21
5 0,97
6 0,81
1st 11/35
2nd 19/37
3rd 29/43
4th 34/41
5th 35/34
6th 37/30
TL4 031
1 3,36
2 2,10
3 1,51
4 1,21
5 0,97
6 0,81
1st 11/37
2nd 19/40
3rd 27/41
4th 34/41
5th 35/34
6th 37/30
TL4 003
TL4 024
TL4 031
This documentation is for the standard boxes which all have a 4.31:1 ratio.
He needs the red line values of the diagram in the following link.
If nobody here can help you may ask directly at Pure MS.
Firstly we need to know what box you’re running and what your tyre sizes are but there are plenty of gear speed calculators out there. I used an old Subaru one for mine, which gave me all I needed.
I changed FDU to 4.73, changed 1-3 ratios and ran different size tyres and it’s bang on.
