Can someone let me know where the fan switch and the thermostat are located on a 197. Thanks
AJ68 Apr 13, 2015 #1 Can someone let me know where the fan switch and the thermostat are located on a 197. Thanks
Foxspeed "the new red baron" Moderator Apr 13, 2015 #2 no fan switched it worked via ecu thermostat is on the end of the cylinder head in the "thermostat housing"
AJ68 Apr 13, 2015 #3 Ok thanks pal, much appreciated, is the thermostat housing on the right, just up from the dipstick?
Foxspeed "the new red baron" Moderator Apr 14, 2015 #4 AJ68 said: Ok thanks pal, much appreciated, is the thermostat housing on the right, just up from the dipstick? Click to expand... that's the one
