Engine rebuild specs
Starslet
Hi
I'm after some specs for rebuilding my 197 engine. I can't seem to find anything on bearing clearances, bolts that need to be replaced etc. Does anyone have a manual? I've seen the R3 maxi engine build manual mentioned multiple times, but couldn't find it.
Thanks a lot!
I did look you will have to speak to an engine builder as the Renault service manual only shows crank seals and head torques Renault sport manuals will not be much good as engines are sealed for championships so I would suggest buy parts from an engine builder and while doing so get the spec data from them along with the parts or tell them your measurements and they will supply what's needed. There is you tube videos for building 172 engines and one I saw was a white board with engine spec data on it
