Engine Noise at idle?
Denners15
Gold Member
Has anyone experienced this noise before, sounds like it’s echoing through the manifold? Metallic chattering noise, increases with the revs but then disappears after 1.5k
any help or guidance appreciated
Does not disappear, don’t believe it’s clutch related although my release bearing is squealing and needs replacing
Check your exhaust heat shield(s)... There's one on the rear diffuser, I've popped about 20 more rivits in mine to stop this from rattling, worked a treat. Also you'll have like a sheet of 'dimpled' heatshielding that runs the entire length of the car from the end of the manifold to the rear. Might be a loose bit that's touching the exhaust etc.
The best way to find the noise is to get as close as possible to where the noise is coming from and start your investigation from there.
I hope this helps and you get it sorted :smile:
Hi Frank thank you for your comment, I don’t believe it is the heat shield as it is a solid metallic juddering sound rather than a reverb form the heat shield, also I have had more clips put in to stop some noise I originally had, it’s more coming from the manifold branch/back of the engine. It is a toyosport manifold and has got the appropriate Powerflex fittings on so It’s not banging on the sub frame. Just seems like a strange one to me, I do wonder if it’s anything to do with the timing on the car or the injectors but without proper diagnosis it could be anything
Polybushes don't automatically mean it isn't touching the subframe, they are hit-or-miss (mind the pun) on quality that means it might hit the subframe still, so I would double check that.
We had the car up on a ramp recently when it was having some work done and we checked the clearance to the sub frame and checked to make sure we couldn’t manually knock it. Will get it back up to have another check and see. Defiantly at the front end of the car, being that I can feel the noise vibrate it could be a case that something is knocking around
Reactions: suj
Problem with noises and vibrations, they can travel through structures and make you think they are in places they are not.
I hope you find what it is, noises in Clios are the bane of our lives!
