Right I think I've solved this noise issue! Auxiliary belt removed and it looks fooked..
Walker2686 Sep 11, 2018 #21 Right I think I've solved this noise issue! Auxiliary belt removed and it looks fooked..
Walker2686 Sep 11, 2018 #22 A couple of vids, one with the belt on, the other with it removed and the knocking noise is gone. So now I just need to pick up a new belt and refit! If you check out this quite recent thread it looks to be the same issue.. http://www.clio197.net/threads/knocking-noise-maybe-dying-ac-compressor.59727/#post-694512 Any reason for this happening? Reactions: suj
Walker2686 Sep 11, 2018 #23 New belt fitted and problem solved! The massive chuck missing from the grooves must have been causing the tapping noise. Reactions: wootwoot, Big Ben, Rishi and 2 others
