petercronin
I had a struggle a while ago finding the part number for the o2 sensor, the only way you’re going to know for sure is to get under the car and have a look.
Engine rebuild due - DIY? | Clio 197 Area | 2 | |
K | Engines 197/200 | Clio 200 Area | 3 | |
R | engine fault code help | Engine, Gearbox, Exhaust and Air Intake | 3 | |
If I've had an engine warning light flash, but then go off, can a fault still be foun | Engine, Gearbox, Exhaust and Air Intake | 21 | |
Engine fault codes | Other Marques | 1 |
