Because i'd much rather work with the engine I currently have and know the history rather than one taken from a crashed car!
good for you pal :thumbsup:
So can a Clio ECU be mapped to run bodies do you think then if it can be mapped to run boost?
I agree these kits are good for the people that want a quick upgrade that will take little set up and install time. However i see my clio as a project and therefore the forged meg conversion is the way to go. You get much more bang for the buck, as I have bought a whole engine, forged con rods, pistons, inconel valves, uprated srpings, helix clutch, arp bolts, 250 turbo (Will be upgraded once the engine is bedded in) for 3.5k so all i need is to install it, which ill try and do myself. Splicing the loom doesnt look to tricky, just have to change a few pin positions etc
what compression they using???
wouldn't want to use standard c/r with standard 197/200 rods + turbo...I don't think they are that strong :coffee:
and its not as if its di either for a bit of added protection
Their 182 turbo kits are very good and proven so i would imagine that it would follow closely and use forged Pec low compression pistons and forged rods. Using the std head gasket would produce a compression ratio of 8.8:1. you could take that down using thicker head gaskets if you wished.
Engine Dynamics Promo Code | Group Buys/Discounts | 4 | |
Engine dynamics mapping | Clio 197 Area | 9 | |
Trader Engine Dynamics welcome back | Site Traders | 40 | |
Engine Dynamics | Engine, Gearbox, Exhaust and Air Intake | 0 | |
| C | engine dynamics quick shift | FI | 3 |
