chris_blue
Clio 197 failed emissions today- big style
CO2 was 10% (Should not be above 0,2%)
HydroCarbons 900-1500ppm (Should not be above 200ppm)
Lambda 0.7 (Should be between 0.97-1.03)
Tester suggested new LAMBDA sensors and new Catalytic converter
That seems strange when i only fitted the Milltek sportscat 3 year ago- can they go that quick? Ive done 3 or so track days a year
Its a milltek resonated sportscat set up
Should i just go ahead and replace the sensor (Or is it 2 sensors on an aftermarket milltek system with TOYO manifold?) and the sportscat- pricey
OR- Run thought some Cat cleaner and maybe change the sensor
Not sure what to do- anyone any ideas?
