Electrical Fault!
Hi all,
Started the car up yesterday and immediately the spanner light came on and it now says electrical fault on the screen, none of my interior lights work, sensor wipe dosent work, my rear wiper is having a mental, iv checked all the fuses and they seem to be fine.
anybody had this same problem or similar?
Right I've had the car checked and the body control module/UCH is playing up, it was throwing up loads of faults, the mechanic said that i would have to take it direct to renault as they have to codes for the car, has anyone had the same problem or any advice on what to do? As i don't really want to take it to main dealer becuase they will charge a fortune
Hi mate, i have exactly the same fault symptoms... no interior lights, no radio, no auto wipers, rear wiper is going loopy, no cruise control yet the speed limiter works which is odd because they are the same switch! Also no time or temperature on the center display, spanner light is on and it says 'Electrical Fault'. Just wondering if you managed to get it fixed?
