Driveshafts lifespan?
Discussion in 'Engine, Gearbox, Exhaust and Air Intake' started by bedoef, May 9, 2019.
  1. bedoef
    bedoef Platinum Member
    84
    Dubai
    Car:
    2012 Clio RS 200
    Anyone know what the expected lifespan of the driveshafts on the Mk3 Clio is? Mine have done just over 115k kms, and looks like the shorter one (drivers side) has a CV joint that is going bad. I want to figure out if its because of mishandling from the last garage, or age.
    Also, when I replace it, should I change both or just one?
  2. youngarthur
    youngarthur
    271
    I have a meglio, with a 225 box. I had the CV joint started to tick on lock, so used the original shaft, with a new CV joint. Car is used for shopping, and around 6 track days a year, so my driveshaft, has lasted around 8 years, 75000 miles. Changing only one, will be fine.
  3. Big Ben
    5,384
    Herts
    Car:
    197
    Does it have a rubber outer gaitor or plastic?
  4. youngarthur
    youngarthur
    271
    Rubber Ben.
  5. bedoef
    84
    Dubai
    Car:
    2012 Clio RS 200
    Do you recall where you got the CV joint from / the part number? I wouldn't mind trying that as a fix
  6. Big Ben
    5,384
    Herts
    Car:
    197
    Thanks Arthur
  7. youngarthur
    youngarthur
    271
    Euro car parts, and a few others.
    bedoef likes this.
  8. bedoef
    84
    Dubai
    Car:
    2012 Clio RS 200
    Thanks, will have a look!
  9. bedoef
    84
    Dubai
    Car:
    2012 Clio RS 200
    Right, so my garage is telling me the longer driveshaft is bent. I had no warning until I started getting a vibration when pulling away from a stop.
    Anyone experience a bent driveshaft on the 197/200s? Are you lowered or stock?
    Is this a normal thing for our cars?
  • Share This Page
