can someone tell me how you get this to display on the dash please :thumbsup:
you press either the top or the bottom button on the end of the right controll stalk when starting the engine,
i think, :book:
Quick question about how the oil dipstick on the dashboard works, I have never checked this regularly however recently I have and could swear its changing. Currently looks like this:
MIN|O|_|_|_|_|
What's normal? When I start the car I get "OIL LEVEL CORRECT"
Thanks in advance.
Thanks for all the help guys, not too sure what's going on with it, as I could swear there was more than |O - ------| in a few days/week ago.
Running absolutely fine - shall I just keep an eye on it? Or do I need to get it looked at?
Open the bonnet and manually check, best way to be sure.
i used it today when i went out for my lunch, an came up.
Was showing |O|_|_|_|_| so checked the dipstick an surely enough its jus below minimum :glare:
gonna have to get some oil.
whats the best oil to put in folks? :huh:
Will do mate thanks - any particular places to check for leaks? Common?
It does not matter what make oil you use to top it up with as long as its 5w-40 but I like to use Elf.
cheers dude, fully synthetic yeh?
| F | Cutting dashboard for cage | Clio 197 Area | 1 | |
| O | 197 Dashboard mechanical noise | Clio 197 Area | 9 | |
| M | Electronic fault on dashboard | Clio General Chat | 0 | |
Dashboard Display - What Does It Do? | Clio 200 Area | 3 | |
Dashboard dipstick | Clio General Chat | 4 |
