Cylinder head minimum thickness (meg 225)
Stephenvenning
Gold Member
Does anyone happen to know the minimum thickness the cylinder head can be, as I'll be taking the megane cylinder head to a machine shop to be skimmed soon
if theres no warp (maximum 0.05mm) on the head then a clean up skim 0.006' is fine
spec I have is 138.15mm for f4r - it also says no head regrinding allowed...
using multi steel gasket it needs to be a very good finish for it to seal
Multi layer gasket is essential for a forged engine. Thickness will change compression ration though:
Megane 225 / 230 - (42.4cc Head) - Red denotes OEM gasket and comp ratio
0.65mm - 9.1:1
0.85mm - 9.0:1
1.30mm - 8.7:1
1.60mm - 8.5:1
Okay thanks for the input guys. I'll take around 0.1mm to 0.2mm off and then get the 1.6mm multi layered gasket to make up the difference.
