Are you planning to change the suspension? Because is so, then the ''no cup'' option won't make a difference, cup chassis on the 197 is just the dampers/springs (ok and the red calipers). On 200 though it is quicker rack and thicker ARB which make a difference and it is very expensive to retrofit.
On the other hand, if you are not planning to change the suspension then it's cup all the way IMO.
