Clutch Replacement - Additional Parts?
19Zen
I recently started getting a whine/squeal on cold starts, which disappears when warm and now found when I touch the clutch I can make it happen at will. I'm coming up to 100k... clutch travel and bite is good but is probably the release bearing.
While I'm there what would be worth replacing? I'll do the RMS as it's leaked almost from new but wondering if there's anything I might aswell take care of at the same time?
Cheers:smile:
This noise is really quite strange, definitely seems to be the slave cylinder but it only makes the noise if I start the engine cold with the clutch to the floor, then the noise stays whenever I use the clutch, until warm. If I don't touch the clutch pedal on start up then no noise.
When I do replace the clutch I'm thinking RMS, ARB bushes, maybe 200 Cup rack...
If you're doing the RMS, I would advise new flywheel bolts.
ARB bushes makes sense given the frame is off. 200 rack isn't really worth the outlay unless you can find one cheap imo
Reactions: 19Zen
