Hi,
When I first get into my 197 the clutch pedal has no resistance, and I have to almost ‘pump’ the clutch pedal to get any resistance, which works for almost 5 minutes of driving before the pedal starts to get less resistance. I then have to pump the pedal once again to get any resistance. Seems like a leak but fluid levels have not changed, bled the clutch and that worked for 2 days then started having the same issue again. Can anyone help!
ALSO
another issue im having, I have an ABS issue which is a ring which I know of but when the ABS light isn’t illuminated on the dash my brakes make a horrible noise, it’s almost ‘on’ and ‘off’ every second! But once the light illuminates it say ABS has been turned off it doesn’t make any noise. This would steer me away from discs and pads.
PLEASE HELP IVE BEEN TEARING MY HAIR OUT TRYING TO UNDERSTAND WHATS GOING ON...
Thank you
ALSO
Thank you
