Clunk when clutch disengages
lewisflintham
POTM Winner - November 2016, August 2017
Gold Member
Just wondering if this is normal or not. I've noticed that sometimes, there's quite an audible clunk from under the car when the clutch disengages. It's when you're coming to a stop. You can get it to do it most times if you put it into first as you slow down, then as you're braking, the revs drop as to clutch disengages and it goes "clunk". Anyone else noticed this? Thanks.
Yes i've noticed it. Try race mode and open windows. Then just drive a few meters, stop and drive again. Very small amount of throttle. Just like manouvering. I think it's normal.
There is a slight clunk in auto/when the computer takes over and downshifts 2>1.
Apparently to do with the dry clutch gearbox & electronics set up and normal.
Reactions: lewisflintham
