Hi everyone new to the forum and was hoping for some suggestions on my non starting F1.
6 weeks ago I drove the car into my garage and there it sat until Friday. When I came to take it out it wouldn’t start, the engine is turning but won’t fire up. Over the weekend I have charged the battery and checked all the fuses under the bonnet to eliminate the obvious. I have no faults or engine management lights showing on the dash and my generic PCM ECU fault diagnostic tool has flagged nothing from the OBD.
I noticed after multiple attempts at starting that I couldn’t smell any fuel which I considered odd as it should have been flooded. I lifted the back seat and checked that the fuel pump was getting power which it isn’t. Using a power probe I tested the fuel pump which did run but I have no way of proving the pressure it is producing. I reconnected the fuel pump and it primes correctly when the ignition is turned on but does not run when cranking. As a test I tried separately powering the pump while cranking the car and it still will not start. I have now run out of ideas so any help would be a welcome bonus.
