Clio 200 cup chassis vs coilovers?
Thanks for all the replies.
very good point about if I’m going top mounts may as well gaz with included top mounts
Im finding it really difficult to get a definitive view on the specs of how much camber each top mount will allow.
In all the specs it doesn’t seem to mention the range of adjustability
Thanks
mike
I’ve got Gaz top mounts and I’ve got just over 3.5 degrees on mine which is nearly full tilt.. you don’t want any more than that
Thanks for the reply - presume you have Gaz coilover as well? Believe the Gaz top mounts are only compatable out of the box with Gaz suspension?
Yeah I’m running Gaz golds as well.
Believe you can get ast or combrake adjustable top mounts that fit the oem suspension
