Beany
Definitely take Beany up on his offer on a ride in his 200, because as well as being a top bloke, he's also one of the people who loves his car and that enthusiasm might rub off![]()
Flattered mate, you after something
Had clio 197 less than a week and finding it a bit hard to live with. The flat spot at 2000 rpm, the general poor quality really disappointed.
Had car to DDC Renault specialists in doncaster and they said it's one of better ones they've driven and has no faults (I'd hate to have one of the worse ones).
Not new to renaultsport cars I've had a 182 and a megane r26 f1 and this is by far the worst.
Anyone else had this feeling? Will I adjust?
Just for the record car is a mint low mileage example in a really nice blue (renault racing blue I've been told) with fsh. Just had all belts and waterpump done. HELP!!!! Have I made a massive mistake?
Thoughts please guys
Echo what's been said here
firstly check the exhaust Is original and complete
If the belts have been done, and not by some one who knows what they are doing, the timing could be out. If out even by a few degrees it will be done on power/flat spotting
if it was me I'd get it to a specialist in here to check the timing, not the place you bought it from
That's true, but I reckon it's worth cleaning/replacing as it's one less possible causeIs crank sensor associated with cars not starting rather than my issue? Is crank
Hi guys
bit of a development.
i thought that the car had an awful flat spot that I have been complaining about. I no longer think this is the case!
i have gone from the flat spot symptoms to hesitation throughout rev range. It is intermittent sometimes fine then other times seems to misfire not really sure how to describe it. It doesn't pull cleanly above 3k rpm it stutters almost.
exhaust all checked. 100% standard and intact.
new plugs
new cam sensor
new coil packs x4
vvt solenoid removed checked and cleaned
had all modules checked twice now for fault codes but nothing showing / logged.
any of you guys had this issue.
i can try give more info but not sure what to say about it. Need to sort asap as it's driving me fu*#ing wild
What fuel are you using @Bigstu77? I have driven cars with these symptoms in work and you wouldn't believe the fuel quality that came out of them! Another thing I would do that only take 5-10 mins is remove the throttle body and see how dirty it is, give it a clean. Not saying these will fix your issues but just a thought. Hope you get it sorted m8.
Hi,
I am new to this forum.
Bought the 200 4 weeks ago. But I have the same feelings as @Bigstu77.
Really disappointing. I have a flat spot between 2500-3000rpm depending on the throttle position.
The pre owner had removed the pre silencer behind the second cat with a straight pipe.
Meanwhile I have installed a RSTuner cal file I received from Henk, after telling him my car configuration. Was good for two or three days. Now it is back.
Driving slowly is really awful.
I cleaned the throttle meanwhile, I used a zip tie for the map sensor. But nothing helped.
At the moment I am thinking about selling the car. Never had such problems with a used car. (And I drove a lot of old minis...)
(And there are no trouble codes for the engine ecu.)
Fuel at the moment is RON102
And in the last 4 weeks I changed cam belt, aux belt, 3 engine mountings, new tires, 4 new brake discs with pads, 4 new spark plugs, etc.
I do agree driving slowly in the Clio is rather painful though. It's very hard to crawl through traffic/lots of stop start. It's quite jumpy and the throttle sensitivity is a bit "weird" (even more so when cold) - not like anything I've driven before.
| K | Restoring my Clio 197 | Clio 197 Area | 0 | |
Clio 197/200 Rotrex supercharger bracket kits | For Sale | 0 | |
2006 Ultra Red Clio 197 - Trackday ready £4,500 | Clios For Sale | 0 | |
| A | RPM signal for shift lights - Clio Sport 197 (2008) | Clio 197 Area | 0 | |
After 6 years of RS Clio 197 ownership... | Clio General Chat | 11 |
