Yes, make sure the arms on the callipers are all the way back against there stop, chances are your handbrake cable on one side or the other has stuck, manually pull it back and then pump the pedal say ten times with the engine running and then see what the handbrake is like, very common If your lucky it’s just a bubbled cable inner, in which case cut the plastic sheath off and grease liberally, if your unlucky it’s a sticky caliper, in which case it’s a case of lubricate it with penetrating oil and see if you can free it off, if not it’s a new caliper
