Cilo's on the Dyno
Anything less than 185 can you please not post it on here, it upsets people :smiley:
I'll say 188.2
right run it.. I do have bluefin on it .....
made 199.7bhp and 212 nm torque
I know these run lean as standard from factory from what read but between 4000rpm and 5000rpm i have lamdda 1.0 (14.7 afr) and then go down to 0.8 - 0.85 (12.5 afr) @ 7000rpm.
Taken on phone
What reckon guys????
Taken on phone
Good result, you could've have told us about the bluefin before we guessed.. Lol
I was keen for the bluefin after reading that thread. your dyno results seem promising! Does it drive any different mate?
I should of but forgot take handset.
After looking at a fueling graph of standard car this is running lean.
Yes I can tell its on. Seems to pull stronger and pick up better.
(Edit - just drove car standard and can tell map is removed)
I've took it off as I'm not happy, so just get money back. It was a risk, was either going work or not with been a generic map. That's why had dyno'd straight away to check.
