Albert540
Out of the blue (I've just done several hundred kms in the last 2 days) my Clio won't start anymore.
At the first attempt it almost started but then it died immediately.
Things I noticed: the whirring sound you hear when you turn the key (even without actually cranking the engine) has changed and is now a lot higher (in pitch) than it used to be.
Also, the throttle body is emitting a lot of strange electrical noises...
I disconnected the air inlet hose in order to see the actual throttle valve and I see that it responds strangely to changes in the throttle pedal: it stays fixed in its rest position until I press the pedal almost fully, then it opens completely (this is also reflected in the value reported via the OBD). Not sure if this is normal behavior when the car is off...
No error codes whatsoever reported by the ECU.
Any ideas? Throttle body? Fuel pump maybe?
