Can't lock or start car
Spanky-197
Hi
It says my boot is open on the dash even when it's closed, so the car locks then unlocks straight away and if you try to start the engine it says boot open and does nothing?
Well it should start with the boot open. Weird, check the catch at the bottom of the boot has not come loose?
Mine never has been able to start the engine with the boot open, it maybe an option you can turn on and off?
faulty boot lock...
it does it so when your at the rear someone cant jump in the drivers seat start it up and drive away!
Yes it's a keyless one and it will start with the key card inserted, the boot latch is working as I have to use the button to open the boot, so will it be this boot switch?
