Cambelt service
Done a fair bit of searching on this and still not sure
Im going to do the Cambelt (full kit) water pump , oil , all filters and plugs.
The car gets used daily and sees track at least once every few months. I do drive it hard so is it worth me doing the dephaser pulley ?
Also do I need just the aux belt or full kit.
You need
Cambelt Kit
Aux Belt kit
Water Pump
End caps
Crank bolt.
I haven't heard many people completing the dephaser yet - infact not 1....
Let me know if you need the parts As I can supply them all ( bar the dephaser ) for £220 delivered from Renault-
S
You need
Cambelt Kit
Aux Belt kit
Water Pump
End caps
Crank bolt.
S
Cheers for clearing that up.
I work in the trade so our parts lad is pricing it up for me.
If your cheaper ill be in touch if that's ok?
Yep- I will be cheaper - but depends if your parts man is using yin yan belts-
the above price EXC plugs & filters-
S
