Ok, a bit more information for you guys.
In order to install the cams and carry out the mapping we would need the car in our workshop for a full day. The cams we are using are the Catcams 5504402 profile and they need to be timed up correctly using the special Catcams tool which you can see on this page: http://www.k-tecracing.com/news.asp?b=true&nav=6
To date we have never had a problem with a remap reverting back to OE settings. We had heard of this last year and once we looked into it the only thing we could find is that this could happen if only some small, minor changed were made to the parameters (ie. man in van turns up to map the car on your drive, having not done one before so uses some very basic changes in order to justify charging you). The remapping we carry out is much more in depth so there is no chance of this happening.
The cams will be available separately for £649+vat for the pair.
David.
David.
