Brembo discs and pads
If you're buying Brembos the best place I've found is Nextdaybrakes, they're an approved brembo supplier.
http://www.nextdaybrakes.com/
I'm changing mine in the next month or so, going to Brembo HC discs and ds2500 pads. Seems to be the favored setup for fast road use that I've seen whilst doing research.
I've just done my brakes and have had EBC drilled and grooved disc ferodo ds2500 pads great setup and no bad on track either
I doubt they are Brembo discs, it will be some cheap discs with Brembo pads and a clever bit of wording in the ad.
I've posted this before somewhere, but GSF Car Parts give 25% discount off all parts using promo code (PISTON25 - taken from PistonHeads forum).
They do Brembo Front Discs for £66.24 (£132.4 ) and Pads for £49.68 = £182.16 - (minus 25%) = £136.62
