I've reads threads on here about the ABS system on these cars affecting pedal "feel".....and obviously seen the ABS delete kits for sale: which i presume amongst other things is to help firm up the pedal therefore ?
This leads me to my car:
When i bought it - it had just had brand new rear discs and pads. I had ALL the calipers serviced, new pins fitted and everything lubed up. I also had all the fluid taken out and refreshed with new before being re-bled. Even after all that pedal feel wasnt as firm as i'd have liked, although very good indeed and a huge-huge improvement over before.
Not sure whether its me or not - but this sloppiness in the pedal MAY have increased in the 4 months ive driven the car since.
Both sets of pads have plenty of meat on them (Like more than 2/3rds). Pistons retracting fine - i have no binding. And i certainly have no leak at any nipples, master cylinder etc. The brakes once "engaged" are fantastic.
BUT - i have probably nearly a full inch of travel on the pedal before anything much happens. Whilst you would get no feel at all from a rock-hard pedal - im just wondering if some play / movement / travel is normal in these cars - even when the system is in "perfect" or even very-good condition as such ?
