Hi all,
I have been noticing that the rear drivers side brakes have been grinding while moving. Not loud, but loud enough to annoy me. I had a look a few weeks ago and noticed that the caliper was a bit worn including the piston bush being torn and damaged, so I decided to replace it. I swapped the caliper tonight, bled the caliper to make sure there was no air in it, lubed up the edges of the pads and the shims and then reinstalled it and took it for a spin.
I still have the noise! There is no noise coming from the other side though. It's almost as if the pads are lightly rubbing on the disc, as when I apply the brakes, the noise goes away. They discs are slightly rusty, including rust on the edge of the surface of where the pads sit, which I suspect is where the noise is coming from. If this is the the cause, how could I remove the rust from the edge? I don't really want to get new pads and discs if I can help it.
Thanks all!
Thanks all!
