Brake judder
So my car has developed brake judder. Nothing when driving, nothing with light braking, like coasting up to traffic lights and nothing under hard breaking but when normally braking you feel a judder through the pedal and steering wheel.
I've read possibilities of warped discs, stuck calipers, ball joints and ABS rings as possibilities, anyone think it sounds more like one thing than the others??
It's usually worn discs or pad build up on the discs after track days.
most likely pad build up on discs had it on a mates 225.....remove pads & discs and just used orbital sander on the discs to remove the build up
