yea i think theyv taken the mecanizm out as i press it and there dosent even feal like a buton behind the ruber any more rough *******s
If you take out the switch you can seperate the rubber from the plastic and you will see the contacts inside are probably all wet and green corroded looking, dry it out and loads of electrical contact cleaner should help it a lot.
