Bolt in Cage - Oulton ( Read 2nd page )
Willis
The Gatekeeper
Still incorrect angle according to nearly all of the harness manufacturers literature. I think there's a couple of diagrams on here somewhere that had a few different examples on. Many will say that harnesses and buckets shouldn't be used without a full cage as well, which the R.26R doesn't have but still uses both...
fmp
Isn't harness angle also to do with the risk of submarining as well as the pressures put on the seat itself???
Willis
The Gatekeeper
Pressure on body parts as well, ideally you want any forces going through boney bits.
They stretch a fair bit under force, surprisingly.
Everyone's opinon on them will be different. But as for adding weight?? Took back seats out, surly cage will weigh less or the same?? :/
If haven't got harness bar not end world. Still. Beable run harnesses, just have make sure fitted correctly :smile:
Fernandez
Gold Member
I have an oulton cage, I can't imagine the seats will weigh the same, the cage is quite heavy.
I'm having a harness bar welded onto it and plan to get some buckets so may even sell the Recaros. I do like the sound of FMP's cage though.
