Hi,
For some time now, various warning messages have been appearing on the display intermittently. So far, these have been:
Stop! Battery charging fault.
I haven’t seen this message for quite a while, but a two months ago it was appearing every day, sometimes even for extended periods while driving on the motorway. As soon as I left the motorway, it would disappear immediately. I connected an OBD reader, and indeed, the charging voltage would sometimes drop to 12.5 volts.
Check ABS / traction control system.
I’ve been having this issue since April. This message appears frequently on the display, but not constantly. I checked the systems (when it was safe to do so), and while the message is displayed, both ABS and TC seem to work normally. I also ran a diagnostic scan, but there were no fault codes stored. I really have no idea what could be causing this. Could the battery simply be sending this fault signal to the ECU?
I’d really appreciate any opinions or advice.
Thanks in advance!
Thanks in advance!
