Bad vibrations
Hello
I have serious vibrations in the steering wheel at highway speeds and below. Especially when turning to the left the vibrations seem to get worse. Car is basically undrivable. The vibrations started off very subtle and in a day of driving ended up where it is right now. Any ideas or what this problem might be??
Wheel alignment and tyre balancing can be so underrated at times. Get it done and they'll likely tell you if any of your rods/arms are failing at the same time.
Something along those lines....my tire separated from my wheel somehow never seen this happen before but thank God all it took was a change of a tire. I'll add a picture for reference. As you can see the tire basically had a bubble all the way around
