Are these te right ones ?
Well the top mount changed around the middle of 2010. Yours being a 60 plate could have been built before or after the change. The only way to go with yours is too check the top mount to see which you have. There's a thread on here somewhere that shows them both. Alternatively if you post a pic with the scuttle panel off we can tell you which you need :smile:
Alrite cheers mate thanks
They're only springs, you're not changing top mounts as with coilovers which is when you need to be careful with the top mounts.
No mate, there are two different h&r springs available. One for the 197 and early 200's and one set for the 2010> 200's you need the right ones I've always been told.
Apologies, didn't know the top cup/pan was a different size on them too:
"Features
Only for cars with front spring pan inner diameter on 83mm"
Learn something new every day :wink:
