AP Coilovers
I was told they didn't fit 197s but maybe there is a set now. If you can push a little further go for spax? I'm deleighted with myn and are still comfy, plus the adjustability for less than kw v1s.
They didnt, but those where for the non rs 2.0l, they werent clearly identified. But these are for 197/200, it looks like they do a set for the later cup suspension aswel.
So they do make coilovers for 197? Any have them fitted on the car? Or the KW v1 is better? But it cost more money :worried:
Just wont to have better setup then this right now: serial shock absorber and eibach springs.
Yeh as it says for 2.0 RS 145kw, which is 197/200, also states two versions which by the dates given the 197/early 200 and the later changed 200 cup setup. I dont think anyone has this yet as there quite new. You could always be the first and give some feed back of what there like.
Obviously kw are better, ap are budget coilover made by kw. But i have heard good things about ap on other marque cars.
The articke number is always GF90-023 or GF90-032. On any motor I choose i get this 2 part numbers. Hm strange
Gf90-023 are 197/200 year 2005-2010, gf90-032 are for model 2010 onwards (200 with the changed topmounts) well thats how i read it anyway.
Yes but if you choose another motor in clio like 1.6 the par number are the same again: GF90-032 (08/2010-) and GF90-023 ( 10/2005-). I just hope that the AP coilovers are not the same for every motor in clio because from the part number are the same....
I see want you mean, well the best place to answer ya question would be ap suspension them self.
Thanks i am afraid that if those Ap are the same for each motor then i dont know....its not very encouraging. After all clio have the perfect serial suspension.
