Ive done a search but cant work it out for sure,can they be fit to a 197 and if so do you need to change the diffuser ?,or will it bolt straight on?,Thank in advance for the help guys
Mark
yeh its direct fit, someone on here had one fitted, you will need tailpipe made up for the factory look or tailpipes made for what ever tailpipe desigh your after.
No the exhaust is essentially the same on both but if you get your head down and look at the 197 exhaust there are tips welded on to the end of a straight cut pipe. The 200 just doesn't have a tip on which means they sit further back.
From what I have seen the Arkapovic is essentially a 200 exhaust shape. Plus you will be able to sell the 200 style carbon fibre tips to some one for a nice price IMO!
You could, but I would keep them in case 1) you get a 200 diffuser or 2) you want to sell the exhaust. I can imagine it would be quite hard to sell without the tips.
Harmo, I've got one on my 197, jamsport did mine!! Do it through them as they have the in the shelf trims to do it!! Search my threads and you'll see pics, fantastic exhaust mate.
It's fine dude, very nice!! Quite and sporty when you don't want to hear it then full of win when you boot it! Sounds a bit more aggressive with the cams as well, at 7.8rpm...wow lol! when you gettin yours woody?
Nice one harmo, the jamsport boys will sort you out, think mine arrived in about 10 days iirc.
