Hi, I appreciate this has probably been covered somewhere along the line but from searching I haven't yet found a definitive answer so apologies if so!
From what I've read I'm understanding it as people saying cat back systems run from after the secondary cat and require the exhaust to be cut, regardless of if it's resonated / non resonated?
So in order to not have to cut the standard system I would require a decat (then from what I see encounter a flat spot issue..)
So I have two questions..
a) is the flatspot issue still just as prominent with a decat followed by a resonated system?
b) I will attach screenshots from demon tweeks, systems I've been looking at which suggest they run from the primary cat (pre cat on a 197?) and replace the secondary cat.. is this correct or wrong info on their part?
Thanks in advance,
Lee
Thanks in advance,
Lee
