Adjustable Top Mounts
My car is a Clio 197 2008 so assume it has the large holes for top mounts.
I'm just about to purchase the AST adjustable top mounts to go with Bilstein B14 but having a horrible feeling these won't fit my car. Are they for the smaller hole?
http://www.kamracing.co.uk/car-tuni...solid-top-mounts-renault-clio-mk3-rs-197.html
Or Gaz. These say 197 and 200. How can they be both if there is different size holes or will they fit the smaller and larger holes?
http://www.ebay.co.uk/itm/Renault-C...109464?hash=item2351e97418:g:YAYAAOSweW5VTinz
Or Compbrake. Again 197 or 200.
http://www.ebay.co.uk/itm/RENAULT-C...pe:197&hash=item43dd006a03:g:FtAAAOSwl8NVXcYP
Would you go for the Compbrake or Gaz over the ASTs?
Be careful with the Gaz - I'm sure I spoke to them when we were looking for top mounts and I believe the top of a gaz shock is a different diameter to that of a Bilstein - I stand to be corrected though
We used 'Simmo' top mounts from Italy on B14's - camber adjust only
The Compbrake say Camber and Caster adjustment and the option of 12mm or 14mm sleeve nut - might be worth a punt
197s and early 200s have the same top mounts. So if it says they fit both then that is why.
