I changed the rear discs and pads at the weekend using genuine Renault parts and when driving off had a light on the dash for ABS/ESP.
I scanned it and the code was C1043 with a generic scanning app. Which identified as rear left abs sensor. Pulled it apart and all looked good, the sensor mounting plate has surface rust but isn't corroded through so I wire brushed it up but it still didn't help. Decided it must be the sensor so ordered another.
Fitted the new sensor today and the light cleared itself, the code persisted but I cleared it too.
This evening I've gone for a longer drive and the lights are back, however unlike before where the light would come on as soon as I start driving, the behaviour is now that the car has a strange grind when braking at slow speeds, then once you hit 30mph the abs/lights lights come on and the grinding stops. I also have a different code - C102F, not sure what this is though.
Any advice?
Any advice?
