Hi Guys,
I have been doing a fair bit of reading regarding the Meg swap, I've aquired myself an R26 engine & Box with Ecu & other modules,
Coolant hoses,
Intake hose & Ram Air filter
Megane Radiator & Fan
Megane Loom
Driveshafts
Gearlinkage
Probably some other bits I have forgotten.
Anyway my questions:
Can you recommend me somewhere to get a thermal sheet for the firewall/fuel rails from?
Intercooler, I plan to keep aircon so will be using the Clio rad pack, I have been looking at the Mishimoto J line universal cooler and then matching up the pipework. Is this a sufficient cooler?
Expansion tank, If I am keeping the Clio rad, can I keep the Clio expansion bottle and just relocate it behind the battery as I've seen on other builds?
Downpipe, Is Milltek the only one I can use? I have a link pipe already so that bit isn't an issue.
Gearbox mount, I have the lower half of the Megane one which is attached to the box, can i use the clio top half (the bit under the battery tray) or does that have to be a Megane part also?
I will also be looking for someone to make the loom/Imobiliser swap for me in due course as I understand I need to send both the Clio & Megane looms off? However I am still using the car in N/A form until I have collected all my bits.
Thanks.
Coolant hoses,
Megane Loom
Driveshafts
Gearlinkage
Thanks.
