mate why you uninstall the light weight pulley ? any sort of problems ? i asking because i want to put lightweight flywheel and puley these days ..thank you
Track night at Spa sounds cool Peter! Not heard of the other track?the car's having a quiet life, due to obvious reasons. but that's about to change. first trackday of the year is coming up next thursday at spa-francorchamps, a two-hour 'tracknight', from 18.00 till 20.00. then 9 october a full day at mettet and hopefully a full day at spa-francorchamps again, in november, that is if the british organizer doesn't decide to cancel the event (quarantine issues). i hope it stays dry, so i can finally find out if the yokohama AD08RS really is the crap tyre everyone on the whole internet, makes them out to be.
had the car serviced at the beginning of the year. fresh bardahl XTS 0W40 (engine oil) and elf tranself 75W80 NFP (gearbox oil) going in. didn't change the brake fluid. had to replace a ball joint. can't remember which one though. the front brake discs were done (after three years) and replaced them with another pair of brembo high carbon ones.
Put some pics up mate. Don’t see enough of your lush motor
the car was pulling to the right (last couple of weeks), so i had it geo'd today. allignment was ok, but right side upper and lower balljoints are f*cked. again (third time on the right side). getting that fixed before next friday's trackday.
also, i've been hearing a rattling noise for quite some time now. mostly right after i start the car. then when the clio warms up, the rattling noise disappears. i've had the exhaust heat shield looked at. two rivets had worked loose. had them replaced, but the noise was still there. on further inspection, the honeycomb in the second cat worked loose. so i had that removed. not sure how that's going to effect emission values. will find out when i have to get the car MOT'ed, next month.
Interesting on the Yokos Peter. Are you not allowed a proper semi slick over there? No thoughts of a 2nd set of wheels?
Car looks great still. One of my favourites
How’d you find the Endless brake fluid Pete? Not a common go to brand in UK. Have you tried Motul660 as a comparison?yearly service done :
- bardahl XTS 0W40 (engine oil)
- elf tranself 75W80 NFP (gearbox oil)
- endless RF650 (brake fluid)
I've found the less you hesitate and the more you just send it, the less frustrations and near misses you encounter. Gives a slight element of control over situations.
