200T wheels ...
Week or 2 before Christmas I had a run-in with a kerb after been cut up by some idiot taxi driver. Damaged a wheel pretty badly as you can see. Was going to get it refurbed then I started thinking ... have wanted to either change my current wheels to gloss black or even get a set of 18" wheels from a Clio Raider.
I also like the wheels on the new 200T, put together the attached image.
I know the tyre sizes are different, 205 on the 200T as opposed to 215 on the 200. Does anyone know if the 200T wheels will fit on a 200?
If they did fit would they alter handling at all?
Damaged wheel ...
200T wheels ...
It's a shame really as they look good on there.
Like that! PCD adapters?
The adapters would have to be around 20mm thick to be safe so unless the new 200T wheels have around the same offset (ET68 ) or higher you'd struggle I think.
What is the offset of the new wheels? anyone?
