200 Wheel Info
N0ddie
Been offered a really good deal (On a Corsa Site funnily enough) on some 17" Tam Dynamics Pro Race 1.2 wheels. Will be using them as trackday wheels on the 200.
I just need some info on what offset and stud pattern the 200 wheels are.
ive got these on mine, im running et45 and the stud pattern is 5 x 108 i beleive
renault standard wheels are...
68et
5 x 108 pcd
60.1 centre bore.
on a 7"-7.5" wide wheel youll get away with anything between 68 - 45et
if the centre bore is bigger on the wheels you get you can make it smaller with some spigot rings.
68et
5 x 108 pcd
60.1 centre bore.
Cheers Jase.
Helps a lot.
