200 Cup Anti Roll Bar
av4625
Hi,
I have a 197 with a 20mm ARB. I want to put a 21mm ARB on from a 200 CUP. I think the 22mm version from the cup racer would be too much with out cup racer suspension. Currently have GazGolds.
I was wondering if anyone knew the part number of the 21mm ARB so I could order one?
Thanks!
turkie172
I should have that stuff from the F1 should have had cup pack the anti roll bar might have be a little bent where the drop link bolts on but should still work localised heating should straighten it the anti roll bar uses smaller bushes on a block platform I would have to lift down the boxes and poke around to make sure thats what I have you can have the anti roll bar for nothing.
av4625
oh nice. Thanks!
I had a look on that site but couldn’t figure out which clio was a 197 and which was a 200 and which was a cup etc.
As far as I’m aware. The clio 197 and 197 CUP both had a 20mm ARB with the tall bushes. The 200 non CUP had 20.5mm ARB with short bushes. And the 200 CUP was the only car with the 21mm ARB with short bushes. So if that info is correct I need one off the 200 CUP.
That means I need short bushes (I would get powerflex) and the little blocks under the bushes as mine has tall bushes.
But, I am happy to be corrected on that and it would be interesting to see what size the one you have is!
turkie172
From looking around the site so what I would have is a 20mm one then.
Pre May 2009 (197 Cup & Non-Cup): 20mm
Post May 2009 (200 Non-Cup): 20.5mm
Post May 2009 (200 Cup Chassis): 21mm
RSRowe
^^ This ties up with my part list which we’ve spoke about before Av
av4625
yea all that lines up to what i thought!
I looked up the ARB on a 200 CP1P a 21mm ARB is 8200646063 abot £135 inc VAT new
legend! How did you find that?
av4625
Wonder would I maybe be able to find one of a scenic from a breakers. Anyone know if the part number is on the bar?
