I didn’t realise this i thought it was the fuse box to the side of the battery! I will check this nowIf you remove the battery there is another fuse box underneath there. F8 is a fuse in there dedicated to just the wipers. Should be 20A (yellow).
been great help! Will update tomorrow about 5pm and see if thats the issueShould be three torx (I think) bolts which hold the tray in. Was a right pain to remove due to wiring harnesses and lack of space. The best description I could find of getting to the fuse box is here:
http://www.renaultsport.co.uk/forum/default.aspx?g=posts&t=75844
Just a shame the photos don't work however it's just a case of removing bits till you can access the fuse box. Take your time and I hope you've got a garage to work in![]()
Thank you mate. Top guy!Just remembered you changed the motor. What you'll have to do is physically remove the motor from the wiper assembly(after making sure it's finished a fully sweep, so parked in the middle of your screen). Reset the wiper position by manually moving them to the bottom of the screen, and then reinstall the motor.
Cheers mate will attempt that at the weekend for definite. Just so strage how sometimes hitting the dash can make it come back onI believe that's the control panel for the heating?
I think the issue will be with the actual blower under the dash. I'll try and find out how to remove it as it's not something I've done myself.
Offside drive shaft 197 (long side) | Engine, Gearbox, Exhaust and Air Intake | 0 | |
S | 197 airbag light | Interior and Audio | 8 | |
K | My first Clio - LY 197 F1 | New Members | 5 | |
M | Clio 197 heater | New Members | 1 | |
P | Heater Resistor 197 | Interior and Audio | 9 |
