197 gear change beeper - possible???
Just wondering if it would be possible to rig the green upshift light up to the seatbelt alarm so I get an audible gear change indicator like in the 200?
Any advice welcome. :wiz:
Pretty sure you could fella, if you change to 200 clocks, bet you could modify the 197 dials as well, I'd want to do it on a spare set though!!
Once u have a beep u forget after a few days u get that used to hearing it well I did when I had an rx8 so I wouldn't bother :tongueout:
Ye, someone on here has fitted 200 clocks to their 197. Litchy maybe???? Would like to have a beep on mine too. I'm sure it could probably be done on the 197 clocks though, I bet an electrian could just take the LED light feed and add a beeper in the middle.
