Lateral sensors, configuration
Sean.R
Hi all,
Onto the next issue with the rebuild.
Airbag light on the dash - stopping me going for MOT currently
I have 2 faults
Driver lateral sensor, configuration
Passenger lateral sensor, configuration
I originally thought is was the seats causing the airbag problem, fitted resistors and did not clear the fault so this is what I am left with.
Not a huge amount of information out there so hopefully someone else has had this fault.
With the seats unplugged
Seats plugged in
So had a look at the module under the handbrake
Gave it a clean with some electric cleaned and plugged it all back in -
I know can't see the SRS module on the OBD reader
The airbag and spanner warnings are still lit on the dash
Here is a pick of what I mean by the SRS module
Any help appreciated
Thanks
Also - the car has been off the road for 5 years so can't take it to anyone with a CLIP etc
This is hopefully the last hurdle for MOT
Lateral sensors are in the B pillar (95% certain).
Definitely nothing to do with the seats.
You should be able to find where the cables tee off the loom on each side.
Reactions: Sean.R
If the problem is with the airbags/seats then you might need CLIP to sort it out unless you can get everything back to how the car thinks it should be. If anything has been removed from the original configuration then the airbag system often gets upset.
  • Sad
Reactions: Sean.R and RSRowe
I think these lateral sensors are a new warning
So yep seats and carpets back out and start tracing it
I am really struggling to find some one with a CLIP close enough
However anyone with CS seats confirm if I should have wires coming out of the seat buckle
So I think I may have fixed this
Pulled the interior back out (annoying as it was all glued in place)
Traced the wires and found lateral sensors
Nothing obviously wrong with them and weird both are in fault
So disconnected them and the fault status went from active too memory
Did a clear fault code and they disappeared
Plugged the seats back in and all faults are gone apart from
Driver seat positioning
Played about with it but just no luck
So popped a resistor down the plug and the air bag light went out.
The fault is still there but dash is clear
To late to turn the car on
So will make sure all is working tomorrow
