Yiannis197
Loving the orange on blue, wheels need to be loud but then again I might be biased
How was it to fit Matt, did it fit in the standard pump carrier and I take it the fuel gauge etc still works ok?
Yes it’s a straight fit mate just joining the wiring to the genuine connector but a simple job. Gauge is working fine.
On a turbo car you use a return so that you can have a rising rate regulator and a constant fuel pressure at the tip. If you don't raise the fuel pressure along with boost you end up loosing effective pressure on the injector tip. Less pressure means less flow the injector can make.
3bar of fuel is only 3bar at ambient pressure. If you're feeding 1bar of boost into the engine you only have 2bar of fuel pressure difference. Raise the fuel to 4, subtract 1 for the boost and you have 3bar for the injector to work with.
If it has an in-tank regulator of 5 and and a 3 on rail means that the rail one bleeds the difference to keep 3 bar on injector tip. That setup will not be able to keep the 3bar of injector tip fuel pressure after 2bar of boost (if the pump and injectors are able to flow enough for the engine to make that boost)
The NA engine doesn't have a return because it sees no boost and the ECU knows that the fuel pressure is what the regulator in the tank sends plus the intake vacuum (on parth throtle)
Thanks. Yeah I understand the general workings, and I've just read the 250 fpr gives up to 5 bar at the rail which will be plenty. Also, Matt's (@trackspec197) engine has 630cc injectors (I know as it's my old engine) which compensate for the usage of the clio fuel pump by opening for longer at a lower fuel pressure thus giving the same results as a higher pressure fpr.
For general info, a 'stage 2' RS Tuning map gives 1.4bar I believe on a standard 225 turbo (Matt can your turbo gauge show boost?) So 2 bar of boost with a 250 turbo would give near high-300 bhp so shouldn't really be an issue on most builds.
Where does it end? 2003 Clio 172 | Projects & Progress | 3 | ||
S | S88THL - Supercharged Clio 200 | Projects/Progress Threads | 3 | |
K | Ricambi tuning exhaust for MK3 Clio? | Clio 197 Area | 1 | |
C | Clio 197 alternator | Clio 197 Area | 1 |
